مشکل بستن چت سایت یاهو
    [سوال] مشکل بستن چت سایت یاهو
    من تمام پورت هارو بستم اما کاربران میتونند از طریق سایت یاهو چت کنند چطور میتونم چت سایت یاهو رو برای کاربران غیرفعال کنم؟
    WWW.TRUSTNET.IR
    "Yahoo! Messenger will automatically search the firewall for an open port, and, if it finds one, use that to connect".
    The order in which Yahoo Messenger scans for available ports is:
    1. port 5050
    2. port 80
    3. All available ports
    This means that blocking Yahoo Messenger by blocking ports will not work. Yahoo Messenger will only switch ports and use a different one.Even if you were able to block Yahoo Messenger by this method, your employees or students would just change to Yahoo Web Messenger - which is accessed as a web page in Internet Explorer or other browsers using port 80.Other information from www.cyberphaze.net (not currently online) gave:
    Yahoo! Messenger
    Service: remote: port 5050, 5150, and 8000 local: 5101 and 1638
    Audio: remote: 5001 local: 1644 and 5000
    File transfer: remote: 1614 local: 80/81/82
    Webcam: remote: 80 local: 1677
    Y!Tunnel
    Service: remote: 1455, 5050, 1071, and 1074 local: 8000, 8001, and 1073
    This site indicates that the ports used are:
    Voice Chat: TCP 5000 & 5001, UDP 2000-5010
    Messages: TCP 5050 which reinforces the information above
    Webcam video: TCP 5100 - which differs from the cyberphaze ports
    Games: TCP 11999
