دایرکتوری proc کاربردش چی هست؟
    اگر اشتباه نکنم محتویات رم را نگه می داره
      1. / – Root
      • * Every single file and directory starts from the root directory.
        * Only root user has write privilege under this directory.
        * Please note that /root is root user’s home directory, which is not same as /.
      2. /bin – User Binaries
      • # Contains binary executables.
        # Common linux commands you need to use in single-user modes are located under this directory.
        # Commands used by all the users of the system are located here.
        # For example: ps, ls, ping, grep, cp
      3. /sbin – System Binaries
      • * Just like /bin, /sbin also contains binary executables.
        * But, the linux commands located under this directory are used typically by system aministrator, for system maintenance purpose.
        * For example: iptables, reboot, fdisk, ifconfig, swapon
      4. /etc – Configuration Files
      • * Contains configuration files required by all programs.
        * This also contains startup and shutdown shell scripts used to start/stop individual programs.
        * For example: /etc/resolv.conf, /etc/logrotate.conf
      5. /dev – Device Files
      • * Contains device files.
        * These include terminal devices, usb, or any device attached to the system.
        * For example: /dev/tty1, /dev/usbmon0
      6. /proc – Process Information
      • * Contains information about system process.
        * This is a pseudo filesystem contains information about running process. For example: /proc/{pid} directory contains information about the process with that particular pid.
        * This is a virtual filesystem with text information about system resources. For example: /proc/uptime
      7. /var – Variable Files
      • * var stands for variable files.
        * Content of the files that are expected to grow can be found under this directory.
        * This includes — system log files (/var/log); packages and database files (/var/lib); emails (/var/mail); print queues (/var/spool); lock files (/var/lock); temp files needed across reboots (/var/tmp);
      8. /tmp – Temporary Files
      • * Directory that contains temporary files created by system and users.
        * Files under this directory are deleted when system is rebooted.
      9. /usr – User Programs
      • * Contains binaries, libraries, documentation, and source-code for second level programs.
        * /usr/bin contains binary files for user programs. If you can’t find a user binary under /bin, look under /usr/bin. For example: at, awk, cc, less, scp
        * /usr/sbin contains binary files for system administrators. If you can’t find a system binary under /sbin, look under /usr/sbin. For example: atd, cron, sshd, useradd, userdel
        * /usr/lib contains libraries for /usr/bin and /usr/sbin
        * /usr/local contains users programs that you install from source. For example, when you install apache from source, it goes under /usr/local/apache2
      10. /home – Home Directories
      • * Home directories for all users to store their personal files.
        * For example: /home/john, /home/nikita
      11. /boot – Boot Loader Files
      • * Contains boot loader related files.
        * Kernel initrd, vmlinux, grub files are located under /boot
        * For example: initrd.img-2.6.32-24-generic, vmlinuz-2.6.32-24-generic
      12. /lib – System Libraries
      • # Contains library files that supports the binaries located under /bin and /sbin
        # Library filenames are either ld* or lib*.so.*
        # For example: ld-2.11.1.so, libncurses.so.5.7
      13. /opt – Optional add-on Applications
      • * opt stands for optional.
        * Contains add-on applications from individual vendors.
        * add-on applications should be installed under either /opt/ or /opt/ sub-directory.
      14. /mnt – Mount Directory
      • * Temporary mount directory where sysadmins can mount filesystems.
      15. /media – Removable Media Devices
      • * Temporary mount directory for removable devices.
        * For examples, /media/cdrom for CD-ROM; /media/floppy for floppy drives; /media/cdrecorder for CD writer
      16. /srv – Service Data
      * srv stands for service.
      * Contains server specific services related data.
      * For example, /srv/cvs contains CVS related data.
