Sysprep ویندوز 7
    Sysprep ویندوز 7
    ویندوز 7 Ultimate
    چند بار Sysprep کردم ویندوز رو ولی بعداز چند تا Sysprep کردن این خطا رو می زنه:
    '' A fatal error occurred while trying to sysprep the machine ''
    چرا این خطا رو میده؟
    اگر نمیشه چند بار Sysprep کرد ویندوز رو چطوری این تعدادش رو زیادتر کنم؟
    This error shows that sysprep was run multiple times on the machine, please open a command prompt, type: slmgr /dlv to view how many times of remaining Windows Activation count. Generally speaking, to sysprep the image on a single computer for multiple times, you need to configure the Microsoft-Windows-Security-SPP | SkipRearm to 1 in the unattend.xml file. I am assuming whether you configure theMicrosoft-Windows-Security-Licensing-SLC | SkipRearm to 1 instead of SPP, the SLC setting is deprecated and should not be used.
    As a work around of this problem, please type: regedit in the Start Search box to open Registry Editor, set the value of GeneralizationState underHKEY_LOCAL_MACHINE\SYSTEM\Setup\Status\SysprepStat us to 7, then run sysprep again.
    If the same issue still persists, please unistall the MSDTC and Reinstall it, then try the sysprep.
    To uninstall MSDTC :- msdtc -uninstall
    To reinstallMSDTC :- msdtc –install
    Best Regards
    [URL]http://social.technet.microsoft.com/Forums/windows/en-US/425bd101-8a87-488c-b2e2-9f2f8113a0d9/sysprep-fatal-error-occurred-while-trying-to-sysprep-the-machine?forum=w7itproinstall[/URL]
    [URL]http://support.microsoft.com/kb/2693187[/URL]
