پيش نیاز سخت افزاري Lync Server 2013
    [سوال] پيش نیاز سخت افزاري Lync Server 2013
    با عرض سلام و درود خدمت همه دوستان
    لطفا در خصوص پيش نيازهاي سخت افزاري و نرم افزاري نصب Microsoft lync server 2013 براي حدود 70-80 كاربر كه حدود 40 نفرشون تو دفتر مركزي و مابقي در 3 شعبه تقسيم شدن راهنمايي بفرماييد .
    ارتباطشون هم از طريق Wireless برقرارِ
    فقط اينكه با توجه به اينكه بخشي از كاربراي اين شركت در شعبه هاي ديگه هستند و ارتباطشون وايرلسِ ،
    1. احتياج به سرور جداگانه براي Edge هست يا نه ?
    2. يا اصلا براي ارتباط با بيرون احتياج به سرور دوم داره يا نه ؟
    3. كمترين سخت افزاري مورد نيازِ ؟
    با سپاس
    برقرار باشيد
    ync Server 2013 server roles and computers running Lync Server administrative tools require 64-bit hardware.
    The specific hardware used for Lync Server 2013 deployment can vary, depending on size and usage requirements. This section describes the recommended hardware. Although these are recommendations, not requirements, using hardware that does not meet these recommendations may result in significant performance issues and other issues.
    Recommended Hardware Platform
    For best performance, we recommend that you run Lync Server on servers with hardware that meets the requirements in the following table. If you use less powerful hardware, you may experience functionality problems or poor performance. Note that these hardware requirements are higher than those of previous versions of Lync Server, primarily because in Lync Server 2013, all Front End Servers run SQL Server.
    NIC teaming is supported and should be transparent to Lync Server. For details, see Communications Server or Lync Server and network adapter teaming.
    Recommended Hardware for Front End Servers, Back End Servers, Standard Edition Servers, Persistent Chat Servers, and Persistent Chat Store and Persistent Chat Compliance Store (Back End Server Roles for Persistent Chat Server)
    CPU 64-bit dual processor, hex-core, 2.26 gigahertz (GHz) or higher
    Intel Itanium processors are not supported for Lync Server server roles.
    Memory 32 gigabytes (GB)
    Disk
    • 8 or more 10,000 RPM hard disk drives with at least 72 GB free disk space.
      Two of the disks should use RAID 1, and six should use RAID 10.
      - OR -
    • Solid state drives (SSDs) which provide performance similar to 8 10,000-RPM mechanical disk drives.
    Network
    • 1 dual-port network adapter, 1 Gbps or higher (2 recommended, which requires teaming with a single MAC address and single IP address)
    Recommended Hardware for Edge Servers, Standalone Mediation Servers, and Directors
    CPU
    • 64-bit dual processor, quad-core, 2.0 gigahertz (GHz) or higher
      - OR -
    • 64-bit 4-way processor, dual-core, 2.0 GHz or higher
    Memory 16 gigabytes (GB)
    Disk
    • 4 or more 10,000 RPM hard disk drives with at least 72 GB free disk space
      The disks should be in a 2x RAID 1 configuration.
      - OR -
    • Solid state drives (SSDs) which provide performance similar to 4 10,000-RPM mechanical disk drives.
    Network
    • 1 dual-port network adapter, 1 Gbps or higher (2 recommended, which requires teaming with a single MAC address and single IP address). 2 network interfaces are required on Edge Servers.
    http://technet.microsoft.com/en-us/library/gg398835.aspx
      Server Hardware Requirements for Lync 2010
      According to Microsoft's documentation (“Determining Your Infrastructure Requirements – Microsoft TechNet”), these are the server hardware recommendations for all Lync Server roles except the Director:
      • 64-bit CPU at 2 GHz or higher; either a dual quad-core or a 4-way dual-core
      • 16GB of RAM
      • 72GB disk space available (10,000 RPM drive recommended)
      • 1 network adapter (2 is better), at 1 Gbps or higher
      Note that these recommendations were based on an 80,000 user pool using 8 front end servers and 1 back end server. If your organization is smaller, you may be able to lower these values to suit you.
      (If you try that, and it works, let me know. I'd love to hear how well Lync works for different business sizes.)
      The Director role doesn't need quite this level of a server. You can use a single quad-core 64-bit CPU (at 2GHz or higher),or dual 64-bit dual-cores.
      Back End Servers and other database servers (e.g.,the Archiving and Monitoring roles) have similar requirements. But there's one difference you should be aware of*, so I'll list them out.
      • *32GB of RAM recommended for Back End Server; 16GB of RAM recommended for the Archiving and Monitoring database (when NOT collocated with the Back End Server)
      There's two advantages of using these recommendations as guidelines.
      –Higher-end servers can use DNS load balancing to help cut down on administration overhead.
      –If you virtualize servers at these specs, they'll have room for future expansion.
      What Operating System?
      Lync Server runs on Windows Server 2008 R2. All versions are supported, except for:
      • Server Core
      • Windows Web Server
      • HPC Edition
      It's very important to remember – 64-bit only.
      http://www.lyncinsider.com/conferenc...rdware-to-use/
