دستورات برای مدیریت دیباگینگ استریسک
  • دستورات برای مدیریت دیباگینگ استریسک
    The subsets of the sip command allow you to manage your SIP connections.
    sip debug
    Turns on SIP debugging. This will be very verbose.
    sip debug ip
    sip [no] debug ip dotted_ip_notationDebugs (or disables debugging of) SIP messages from a specific IP address. This is useful when trying to debug messages coming from a peer who is not yet registered with you or is not configured in sip.conf. sip debug ip 192.168.1.100
    sip debug peer
    sip [no] debug peer peer_name
    Debugs (or disables debugging of) SIP messages from an individual peer, referenced by the peer name configured in sip.conf. Debugging information can be displayed for a dynamic host only if that host is registered with you. If you are trying to debug a registration issue, see sip debug ip. sip debug peer john
    sip history
    Enables or disables SIP history recording. See also sip show history.
    sip no debug
    Turns off SIP debugging.
    sip reload
    Reloads the SIP channel module. This is the equivalent of performing a reload chan_sip.so. Reloading the SIP channel is required to load changes to sip.conf and sip_notify.conf into memory. Active SIP channels are not dropped during a sip reload.
    sip show channel
    sip show channel channelDisplays extended information about an active SIP channel. See also sip show channels. sip show channel 00036bdd-39
    sip show channels
    Displays a list of all active SIP channels. The value in the Call ID column is used by the sip show channel command to display extended information about an individual channel. See also sip show channel.
    sip show history
    sip show history channelProvides a detailed log history for a given SIP channel. sip show history 00036bdd-39
    sip show peer
    sip show peer peer_nameDisplays detailed information about a peer configured in sip.conf. sip show peer john
    sip show peers
    Lists and displays the status of all SIP peers.
    sip show registry
    Lists and displays the status of all peers with whom you are registered.
    sip show user
    sip show user user_nameDisplays detailed information about a user in sip.conf. sip show user 1000
    sip show users
    Displays a listing of all users configured in sip.conf.
    soft hangup
    soft hangup channelRequests a hangup on a given channel. soft hangup SIP/1000-4248
