فروش سوئیچ 24 پورت Linksys
  • فروش سوئیچ 24 پورت Linksys
    فروش 5 عدد سوئیچ نو آکبند 24 پورت(1000) لینکسیس
    تلفن تماس : 7212222984 - 09171233018
    قیمت واحد : 1100000 تومان
    مشخصات
    Linksys SGE2000 24-port 10/100/1000 - Gigabit Switch
    فروش سوئیچ 24 پورت لایه 3 linksys - قابل مدیریت
    امکانات موجود در سوئیچ :
    PORTS :
    24 RJ-45 connectors for 10BASE-T/100BASE-TX/1000BASE-T with 4 shared Gigabit SFP slots
    • Console port
    • Auto medium dependent interface (MDI) and MDI crossover (MDI-X)
    • Auto negotiate/manual setting
    • RPS port for connecting to redundant power supply unit
    SWITCH Capacity : Up to 48 Gbps, nonblocking
    Stack Operation:
    • Up to 8 units in a stack (192 ports)
    • Hot insertion and removal
    • Ring and chain stacking options
    • Master and backup master for resilient stack control
    • Auto-numbering or manual configuration of units in stack
    MAC table size : 8000
    NIMBER OF VLANS : 256 active VLANs (4096 range)
    VLAN :
    • Port-based and 802.1Q tag-based VLANs
    • Protocol-based VLAN
    • Management VLAN
    • Private VLAN Edge (PVE)
    • GVRP
    LAYER 3 Option :
    • Static routing
    • Classless interdomain routing (CIDR)
    • 128 static routes
    • IPv4
    • Forwarding in silicon - wire-speed forwarding of Layer 3 traffic
    IPV6 :
    IPv6 Host Mode
    IPv6 over Ethernet
    Dual IPv6/IPv4 stack
    IPv6 Neighbor and Router Discovery (ND)
    IPv6 Stateless Address Autoconfiguration
    Path MTU Discovery
    Duplicate Address Detection (DAD)
    ICMPv6
    IPv6 over IPv4 network with ISATAP tunnel support
    IPV6 QOS : Prioritize IPv6 packets in hardware
    IPV6 ACL : Drop or Rate Limit IPv6 packets in hardware
    IPV6 Application : Web/SSL, Telnet Server/SSH, Ping, Traceroute, SNTP, TFTP, Radius, Syslog, DNS Client
    IPV6 RFCs Support :
    RFC2463 - ICMPv6
    RFC3513 - IPv6 Address architecture
    RFC 4291 - IP Version 6 Addressing Architecture
    RFC 2460 - Internet Protocol v6 (IPv6) Specification
    RFC 2461 - Neighbor Discovery for IPv6
    RFC 2462 - IPv6 Stateless Address Auto-configuration
    RFC 1981 - Path MTU Discovery
    RFC 4007 - IPv6 Scoped Address Architecture
    RFC3484 - Default address selection mechanism is described by RFC3484
    RFC4214 - ISATAP tunneling
    RFC4293 - MIB IPv6: Textual Conventions and General Group
    RFC 3595 - Textual Conventions for IPv6 Flow Label
    management :
    Web user interface
    SNMP
    SNMP MIBs
    consol
    SSH
    telnet
    Other Management :
    • Traceroute
    • Single IP management
    • SSL security for web user interface
    • SSH
    • RADIUS
    • Port mirroring
    • TFTP upgrade
    • DHCP client
    • BOOTP
    • Simple Network Time Protocol (SNTP)
    • Xmodem upgrade
    • Cable diagnostics
    • Ping
    • Syslog
    • Telnet client (SSH secure support)
    IEEE 802.1x : • 802.1X - RADIUS authentication; MD5 hash
    • Guest VLAN
    • Single/multiple host mode
    ACLs - drop or rate limit based on:
    • Source and destination MAC-based
    • Source and destination IP address
    • Protocol
    • Port
    • VLAN
    • Differentiated services code point (DSCP)/IP precedence
    • TCP/User Datagram Protocol (UDP) source and destination ports
    • 802.1p priority
    • Ethernet type
    • Internet Control Message Protocol (ICMP) packets
    • Internet Group Management Protocol (IGMP) packets
    • Up to 1018 rules
    • Link aggregation using IEEE 802.3ad Link Aggregation Control Protocol (LACP)
    • Up to 8 ports in up to 8 groups
    Broadcast and multicast storm protection
    DoS attack prevention
    Spanning Tree Protocol :
    • IEEE 802.1D Spanning Tree
    • IEEE 802.1w Rapid Spanning Tree
    • IEEE 802.1s Multiple Spanning Tree, Fast Linkover
    IGMP Snooping ;
    IGMP (versions 1 and 2) snooping limits bandwidth-intensive video traffic to only the requestors. Supports 256 multicast groups.
    QOS
    Number of fans : 2
    power :100-240V AC, 50-60Hz, internal, universal; also equipped with redundant power supply connector for external power supply 48V DC
    package Content
    • Cisco SGE2000 24-Port Gigabit Switch
    • Console cable
    • AC power cord
    • Rack-mounting kit
    • Quick installation guide
  • #2
    قیمت به 1000000 تومان تغییر کرد.
    عزیزارن قیمتش خیلی خوبه ها!
