موضوع: Using XP as a router
    کاربر مستعد root آواتار ها
    765
    Post Using XP as a router
    A cheap and easy way of adding a router to your network is to use a surplus PC with Windows XP Professional installed on it. Just install an additional network card in the box and then configure the registry setting below and Presto! Your XP box becomes able to route (forward) IP packets from one interface to another.
    Open Regedit and navigate to:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\Tcpip\Parameters
    Find the following registry value:
    IPEnableRouter
    Set this value to 1 to enable IP routing on the box.
    After doing this, reboot the machine. You may also need to disable Windows Firewall on the machine.
  1. Review: Tomato Router Firmware
    توسط patris_70 در انجمن Others
    آخرين نوشته: 2010/06/11, 04:43 AM
  2. Bring your Network Closer to Five Nines with Graceful Shutdown
    توسط patris_70 در انجمن Cisco
    آخرين نوشته: 2010/04/15, 01:57 AM
  3. Load Balancing in BGP Networks
    آخرين نوشته: 2010/04/15, 01:46 AM
  4. Migrating Your Intranet to IPv6 with ISATAP
    توسط patris_70 در انجمن Microsoft
    آخرين نوشته: 2010/03/26, 03:09 PM
  5. Build a network router on Linux
    توسط admin در انجمن سطل آشغال (Recycle Bin)
    پاسخ ها: 3
    آخرين نوشته: 2006/12/03, 12:31 AM
