موضوع: XP : speedup access to network shares
    کاربر مستعد root آواتار ها
    764
    Post XP : speedup access to network shares
    I have seen reports that Windows XP is slow when accessing network shares. I use XP daily on my local home network and a corporate LAN. I haven't noticed the network slowness. But if you do, there are reports that deleting a particular registry key resolved the problem. It certainly works for Windows 2000. You can give it a try in XP. I would backup the key first.
    HKEY_LOCAL_MACHINE/Software/Microsoft/Windows/Current Version/Explorer/RemoteComputer/NameSpace/{D6277990-4C6A-11CF-8D87-00AA0060F5BF}
    To backup and delete the key, In the regedt32 registry editor navigate to the NameSpace key :
    * Right click {D6277990-4C6A-11CF-8D87-00AA0060F5BF}
    * Click Export. From the Export Registry File dialog box in the File Name text box :
    * Type the filename of your choice as in restoreshare
    * Click Save
    This saves the file names (in my example), restoreshare.reg to the My Documents folder. Its now safe to delete the key.
    * Click Delete
    * Click Yes in the Confirm Key Delete dialog box.
    If your system is unstable or weird after deleting this key, you can restore the key. In Explorer, double-click on your reg file. This will restore the deleted registry key.
    mftmirdamad
  1. Error in logon
    توسط BooMIraN در انجمن مایکروسافت(Microsoft)
    پاسخ ها: 19
    آخرين نوشته: 2011/05/05, 01:59 PM
  2. Using ISA Server 2006 to Extend Server and Domain Isolation Interoperability
    توسط patris_70 در انجمن ISA & Forefront Server
    آخرين نوشته: 2011/02/07, 10:48 PM
  3. ISA 2006 Firewall as a VPN Remote Access Server - A Few Tricks
    آخرين نوشته: 2010/07/13, 01:11 AM
  4. پاسخ ها: 1
    آخرين نوشته: 2010/04/25, 08:49 PM
  5. Enabling the ISA Server 2004 VPN Server
    آخرين نوشته: 2010/03/28, 06:35 PM
