موضوع: How to use RPM Commands
    کاربر عادی navid آواتار ها
    192
    پیش فرض How to use RPM Commands
    This section contains an overview of principal modes using with RPM for installing, uninstalling, upgrading, querying, listing, and checking RPM packages on your Linux system. You must be familiar with these RPM commands now because we'll use them often in the continuation of this book. To install a RPM package, use the command: [[email protected]] /#rpm -ivh foo-1.0-2.i386.rpm
    Take a note that RPM packages have a file of names like foo-1.0-2.i386.rpm, which include the package name (foo), version (1.0), release (2), and architecture (i386).
    To uninstall a RPM package, use the command: [[email protected]] /#rpm -e foo
    Notice that we used the package name foo, not the name of the original package file foo-1.0-2.i386.rpm.
    To upgrade a RPM package, use the command: [[email protected]] /#rpm -Uvh foo-1.0-2.i386.rpm
    With this command, RPM automatically uninstall the old version of foo package and install the new one. Always use rpm -Uvh to install packages, since it works fine even when there are no previous versions of the package installed.
    To query a RPM package, use the command: [[email protected]] /#rpm -q foo
    This command will print the package name, version, and release number of installed package foo. Use this command to verify that a package is or is not installed on your system.
    To display package information, use the command: [[email protected]] /#rpm -qi foo
    This command display package information; includes name, version, and description of the installed program. Use this command to get information about the installed package.
    To list files in package, use the command: [[email protected]] /#rpm -qlfoo
    This command will list all files in a installed RPM package. It works only when the package is already installed on your system.
    To check a RPM signature package, use the command: [[email protected]] /#rpm --checksig foo
    This command checks the PGP signature of specified package to ensure its integrity and origin. Always use this command first before installing new RPM package on your system. Also, GnuPG or Pgp software must be already installed on your system before you can use this command.
    این قسمت شامل گذری بر سرچشمه روش استفاده از فایلهای RPM برای نصب می باشد که :
    Uninstalling
    Upgrading
    Querying
    Listing
    و checking بسته های RPM درسیستم Linux شما می باشد
    برای نصب بسته های RPM از دستور زیر استفاده می کنیم
    foo اسم فایل
    1.0-2 ورزن قایل
    i386 ساختار سیستم
    برای uninstall بسته های RPM از دستور زیر استفاده می کنیم
    برای بروزآوری بسته های RPM از دستور زیر استفاده می کنیم
    با استفاده از این دستور RPM به طور اتوماتیک ورزن قدیمی از بسته foo uninstall می شود و ورزن جدید نصب می شود
    برای query بسته های RPM از دستور زیر استفاده می کنیم
    در ضمن این دستور باعث نمایش اسم بسته های RPM و ورزن و عدد واگذاری نصب بسته های RPM می شود . از این دستور برای تصدیق کردن بسته های RPM که آیا روی سیستم با موفقیت نصب شده و یا نه استفاده کنید .
    برای نمایش اطلاعات بسته های RPM از دستور زیر استفاده می کنیم
    این دستور اطلاعات بسته های RPM مه شامل اسم . ورزن و توضیحاتی در مورد نصب برنامه می دهد
    برای نمایش فایلهای بسته های RPM از دستور زیر استفاده می کنیم
    در ضمن زمانی که بسته RPM روی سیستم نصب شده باشد.
    برای check صحه بسته های RPM از دستور زیر استفاده می کنیم
    ایت دستوریرای check و تعیین کردن امضا PGP تا از درستی و اصل بودن اطمینان حاصل کند در ضمن برای استقاده از این درستور بایدبرنامه های GnuPG یا Pgp روی سیستم نصب باشد.
    دوستان اگر می خواهید در کامپیوتر موفق باشد لطفا زبان خود رو بهتر نمایید
    از navid تشکر می کنم
  1. Guide to Linux commands for beginners
    توسط patris_70 در انجمن Linux
    آخرين نوشته: 2010/06/28, 06:40 PM
  2. More AAA: Simple Authentication, Authorization, and Accounting
    توسط patris_70 در انجمن Cisco
    آخرين نوشته: 2010/05/13, 03:50 AM
  3. SSL VPN Client (SVC) on IOS with SDM Configuration Example
    آخرين نوشته: 2010/05/13, 02:40 AM
  4. Streamlining Functionality in IIS 7.0 with AppCmd.exe
    توسط patris_70 در انجمن IIS
    آخرين نوشته: 2010/04/03, 02:10 AM
