موضوع: squid with dalay pools
    11,159
    پیش فرض squid with dalay pools
    #squid.conf
    #Every option in this file is very well documented in the original squid.conf file
    #and on [فقط اعضا می توانند لینک ها را مشاهده کنند  برای ثبت نام اینجا را کلیک کنید]
    #The ports our Squid will listen on
    http_port 8080
    icp_port 3130
    #cgi-bins will not be cached
    acl QUERY urlpath_regex cgi-bin \?
    no_cache deny QUERY
    #Memory the Squid will use. Well, Squid will use far more than that.
    cache_mem 16 MB
    #250 means that Squid will use 250 megabytes of disk space
    cache_dir ufs /cache 250 16 256
    redirect_rewrites_host_header off
    cache_replacement_policy GDSF
    acl localnet src 192.168.1.0/255.255.255.0
    acl localhost src 127.0.0.1/255.255.255.255
    acl Safe_ports port 80 443 210 119 70 20 21 1025-65535
    acl CONNECT method CONNECT
    acl all src 0.0.0.0/0.0.0.0
    http_access allow localnet
    http_access allow localhost
    http_access deny !Safe_ports
    http_access deny CONNECT
    http_access deny all
    maximum_object_size 3000 KB
    store_avg_object_size 50 KB
    #all our LAN users will be seen by external servers
    #as if they all use Mozilla on Linux :)
    anonymize_headers deny User-Agent
    fake_user_agent Mozilla/5.0 (X11; U; Linux 2.4.4 i686)
    #To make our connection even faster, we put a line similar
    #to the one below. Don't forget to change the server to your closest!
    #Measure pings, traceroutes and so on.
    #Make sure that http and icp ports are correct
    #cache_peer w3cache.icm.edu.pl parent 8080 3130 no-digest default
    #This is useful when we want to use the Cache Manager
    #copy cachemgr.cgi to cgi-bin of your www server
    cache_mgr [email protected]
    cachemgr_passwd secret_password all
    #This is a name of a user our Squid will work as
    cache_effective_user squid
    cache_effective_group squid
    log_icp_queries off
    buffered_logs on
    #####DELAY POOLS
    #This is the most important part for shaping incoming traffic with Squid
    #For detailed description see squid.conf file or docs at [فقط اعضا می توانند لینک ها را مشاهده کنند  برای ثبت نام اینجا را کلیک کنید]
    #We don't want to limit downloads on our local network
    acl magic_words1 url_regex -i 192.168
    #We want to limit downloads of these type of files
    #Put this all in one line
    acl magic_words2 url_regex -i ftp .exe .mp3 .vqf .tar.gz .gz .rpm .zip .rar .avi .mpeg .mpe .mpg .qt
    .ram .rm .iso .raw .wav
    #We don't block .html, .gif, .jpg and similar files, because they
    #generally don't consume much bandwidth
    #We have two different delay_pools
    delay_pools 2
    #First delay pool
    #W don't want to delay our local traffic
    #There are three pool classes; here we will deal only with the second
    delay_class 1 2
    #-1/-1 mean that there are no limits
    delay_parameters 1 -1/-1 -1/-1
    #magic_words1: 192.168
    delay_access 1 allow magic_words1
    #Second delay pool
    #we want to delay downloading files mentioned in magic_words2
    delay_class 2 2
    #The numbers here are values in bytes;
    #we must remember that Squid doesn't consider start/stop bits
    #5000/150000 are values for the whole network
    #5000/120000 are values for the single IP
    #after downloaded files exceed about 150000 bytes,
    #(or even twice or three times as much)
    #they will continue to download at about 5000 bytes/s
    delay_parameters 2 5000/150000 5000/120000
    delay_access 2 allow magic_words2
    #EOF
    11,159
    #####DELAY POOLS
    delay_pools 2
    #First delay pool
    delay_class 1 2
    #Second delay pool
    delay_class 2 2
    #EOF
  1. Set Up Squid on Linux as a Caching Web *****
    توسط patris_70 در انجمن Linux
    آخرين نوشته: 2010/10/24, 04:07 AM
  2. آموزش راه اندازی tproxy
    توسط mt22 در انجمن لینوکس(Linux)
    پاسخ ها: 6
    آخرين نوشته: 2010/08/13, 09:44 PM
  3. پاسخ ها: 0
    آخرين نوشته: 2010/07/23, 05:08 AM
  4. پاسخ ها: 0
    آخرين نوشته: 2010/07/14, 05:00 PM
  5. Integrating Squid and Samba3 with NTLM authentication
    آخرين نوشته: 2010/07/02, 04:50 AM
