موضوع: Deep Freeze Standard v6.20.20.1692 Retail
    کاربر فعال l!nux آواتار ها
    www.com
    1,570
    پیش فرض Deep Freeze Standard v6.20.20.1692 Retail
    Deep Freeze Standard v6.20.20.1692 Retail Compatibility Vista
    Deep Freeze is the standard in bulletproof disk protection
    Deep Freeze instantly protects and preserves baseline computer configurations. No matter what changes a user makes to a workstation, simply restart to eradicate all changes and reset the computer to its original state - right down to the last byte. Expensive computer assets are kept running at 100% capacity and technical support time is reduced or eliminated completely. The result is consistent trouble-free computing on a truly protected and parallel network, completely free of harmful viruses and unwanted programs.
    While Deep Freeze provides bulletproof protection, its non-restrictive approach also improves user productivity and satisfaction. Placing no restrictions on a user's ability to access all system resources, users avoid the frustration of downtime due to software conflicts, operating system corruption, virus attacks, and many other problems. Users are always assured of computers that are consistently operable and available.
    Deep Freeze Standard is changing the way IT Professionals protect small multi-user environments. Simple, robust, and cost effective Deep Freeze Standard is ideal for computing environments with 10 or less workstations.
    Absolute Protection
    Guarantees 100% workstation recovery on restart
    Provides password protection and complete security
    Protects multiple hard drives and partitions
    Protects CMOS
    Protects master boot record
    Integration and Compatibility
    Supports multiple hard drives and partitions
    Supports multi-boot environments
    Compatible with Fast User Switching
    Supports SCSI, ATA, SATA, and IDE hard drives
    Offers single install for Windows 95, 98, ME, 2000, XP and Vista
    Compatible with FAT, FAT32, NTFS, basic and dynamic disks
    Deployment Options
    Offers silent install option for rapid network deployment
    Provides option to deploy on multiple workstations as part of a master image
    http://rapidshare.com/files/22428145/1692.rar
    or
    http://www.megaupload.com/?d=MBVR0GS6
    موفق و شاد باشید
    کاربر عادی ghseda آواتار ها
    Mar 2007
    این نرم افزار نیاز به crack هم داره یا نه ؟
    اگر اره لطفا کرکش رو هم بگذارید ;)
    من دنبال یک نرم افزار دیگه از همین شرکت(Faronics) میگردم به نام Antiexecutable که اگر کرک شده اش رو دارید لینک بگذارید
    www.com
    1,570
    پیش فرض salam
    دوستان این برنامه کرک شده هست ولی ورژن کامل نیست و پیشنهاد می کنم که استفاده نکنید میگردم یک ورژن بهتر و کاملتر پیدام می کنم
    ممنون از توجه شما ;)
    موفق و شاد باشید
