موضوع: Vista Smoker Pro 1.2
    کاربر مستعد root آواتار ها
    765
    Post Vista Smoker Pro 1.2
    Vista Smoker Pro allows you to change various settings in the Windows Registry. These settings can improve the performance for your computer drastically. Our service manager allows you to use service presets to stop and disable services without needing any knowledge.
    Vista Smoker Pro includes a One Button Autotuner that will tune your system to perfection based on your system's configuration. Simple for beginners. Powerful for experts.
    Vista Smoker Pro includes hundreds of settings in addition for the expert tweaker that likes to get his hands dirty. There are over 100 security settings alone.
    With Vista Smoker Pro you will be able to increase performance, increase the security of Windows Vista™, and prevent other users from changing your settings.
    Plus with the new Vista Smoker Pro User Account Control feature you can adjust the settings for User Account Control in Windows Vista™ to make it less intrusive yet just as functional, or you can simply change the settings to really lock down security on your PC.
    Vista Smoker Pro also has maintenance tools to help you keep your computer clean and tidy.
    Vista Smoker Pro now includes "DriveFreeze" a new feature to lock down your removable storage devices so nobody can use them without your permission. You can lock down USB drives, CD-ROM/DVD drives, and floppy drives.
    If you are serious about tweaking your system to absolute perfection, then Vista Smoker Pro is the only choice.
    :cool:
