موضوع: Sun Fire T2000 ALOM/ILOM root pass recovery
    کاربر فعال H.Mehrara آواتار ها
    Tehransar
    1,117
    پیش فرض Sun Fire T2000 ALOM/ILOM root pass recovery
    Hi Padmins' users
    I had a challange for recovering our Sun Fire T2000 ILOM ROOT
    whell here's our challange result ;)
    Power cycle the system by unplugging the server’s power supplies, waiting several seconds and then plugging the power back in. You should see the ALOM booting on the serial management console. Hit “Esc” during the ALOM boot, before or at the point where the display says:
    Return to Boot Monitor for Handshake
    The system will return with this message:
    Return to Boot Monitor for Handshake ESC keypress detected.
    The ALOM enters the “ALOM boot escape menu”. The following choices will be displayed:
    ALOM Menu
    e - Erase ALOM NVRAM.
    m - Run POST Menu.
    R - Reset ALOM.
    r - Return to bootmon.
    Your selection:
    To do an ALOM password reset you must choose ‘e’ to erase the NVRAM. After erasing the NVRAM choose ‘r’ to resume the ALOM boot. You will automatically be logged in as the user ‘admin’ with no password and no permissions. The NVRAM settings will also be reset to factory default. All customizations including the ALOM network settings will be erased and will need to be redefined.
    Solaris , BSD Unix admin.
    business Contact: 09374700196
    www.Mehrara.Net
