موضوع: درایور مودم های Conexant D110,HDA,MDC,v.92,modem
    پیش فرض درایور مودم های Conexant D110,HDA,MDC,v.92,modem
    درایور برای لینوکس های بر پایه دبین و آبانتو هستش
    نحوه نصب
    Custom Instructions for hsfmodem_7.60.00.06oem_i386.deb:
    * Download the hsfmodem_(version).deb to your desktop.
    * Double-click the hsfmodem_(version).deb file. The Package Installer will launch
    * Click "Install Package"
    * The system prompts you for your system password. Type your password in the password field and press .
    * The Installing Package File window appears. Click on the empty right triangle to the left of the word Terminal in the Installing Package File window.
    * A terminal window appears within the Installing Package File window. Click anywhere inside the terminal window and press . The system builds the correct driver for your system.
    * Press to accept the default when the terminal prompts you to enter a region name for the modem.
    * After a few seconds, the name of the window changes from Installing Package File to Installation Finished. Click Close.
    The hsfmodem modem driver is now installed on your system.
