موضوع: Why two same IP address ?
    کاربر عادی Hamed89156 آواتار ها
    Jan 2007
    330
    پیش فرض Why two same IP address ?
    Simple Network versus Complex Network
    Whereas simple networks (namely, networks in which no routing takes place) clients only need their default gateway configured to point to the ISA server's internal IP address, for complex or routed networks, you need to create a path to the ISA server's internal IP address. The client always needs its default gateway set to the IP address of a router connected to the same local area network. The router then needs to be configured to pass traffic to the ISA server, or the next closest router to the ISA server as shown in Figure 4-2. Client A is on a separate subnet than the ISA server, and so the client's default gateway must be set to the IP Address of the router (10.0.0.254). The router then forwards the client traffic on to the ISA server at 192.168.1.254. Client B, which is on the same subnet as the ISA server, only needs its default gateway set to the internal interface of the ISA server
    The Question is :
    Why the ip address of the Router and Internal Ip Address of ISA are the same ???
    Two same IP Address in one subnet ...!!!! is it possible ???..
    Thanks
    11,159
    در isa شما مشخص می کنید که چه ipهایی اینترنال هستند و کدام ها external
    پس از ip 2 بار استفاده نشده
