صفحه 7 از 10 نخستنخست 12345678910 آخرینآخرین
نمایش نتایج: از شماره 61 تا 70 , از مجموع 99
موضوع: آموزش های تصویری میکروتیک
  1. #61
    کاربر عادی farzaam آواتار ها
    Jan 2015
    9
    تو خود wiki هم هست
    دو تا شو اینجا میذارم برات
    pcc:
    / ip address
    add address=192.168.0.1/24 network=192.168.0.0 broadcast=192.168.0.255 interface=LAN
    add address=10.111.0.2/24 network=10.111.0.0 broadcast=10.111.0.255 interface=ISP1
    add address=10.112.0.2/24 network=10.112.0.0 broadcast=10.112.0.255 interface=ISP2
    / ip firewall mangle
    add chain=prerouting dst-address=10.111.0.0/24 action=accept in-interface=LAN
    add chain=prerouting dst-address=10.112.0.0/24 action=accept in-interface=LAN
    add chain=prerouting in-interface=ISP1 connection-mark=no-mark action=mark-connection \
    new-connection-mark=ISP1_conn
    add chain=prerouting in-interface=ISP2 connection-mark=no-mark action=mark-connection \
    new-connection-mark=ISP2_conn
    add chain=prerouting in-interface=LAN connection-mark=no-mark dst-address-type=!local \
    per-connection-classifier=both-addresses:2/0 action=mark-connection new-connection-mark=ISP1_conn
    per-connection-classifier=both-addresses:2/1 action=mark-connection new-connection-mark=ISP2_conn
    add chain=prerouting connection-mark=ISP1_conn in-interface=LAN action=mark-routing \
    new-routing-mark=to_ISP1
    add chain=prerouting connection-mark=ISP2_conn in-interface=LAN action=mark-routing \
    new-routing-mark=to_ISP2
    add chain=output connection-mark=ISP1_conn action=mark-routing new-routing-mark=to_ISP1
    add chain=output connection-mark=ISP2_conn action=mark-routing new-routing-mark=to_ISP2
    / ip route
    add dst-address=0.0.0.0/0 gateway=10.111.0.1 routing-mark=to_ISP1 check-gateway=ping
    add dst-address=0.0.0.0/0 gateway=10.112.0.1 routing-mark=to_ISP2 check-gateway=ping
    add dst-address=0.0.0.0/0 gateway=10.111.0.1 distance=1 check-gateway=ping
    add dst-address=0.0.0.0/0 gateway=10.112.0.1 distance=2 check-gateway=ping
    / ip firewall nat
    add chain=srcnat out-interface=ISP1 action=masquerade
    add chain=srcnat out-interface=ISP2 action=masquerade
    ecmp:
    / ip address
    add address=192.168.0.1/24 network=192.168.0.0 broadcast=192.168.0.255 interface=Local
    add address=10.111.0.2/24 network=10.111.0.0 broadcast=10.111.0.255 interface=wlan2
    add address=10.112.0.2/24 network=10.112.0.0 broadcast=10.112.0.255 interface=wlan1
    / ip route
    add dst-address=0.0.0.0/0 gateway=10.111.0.1,10.112.0.1 check-gateway=ping
    / ip firewall nat
    add chain=srcnat out-interface=wlan1 action=masquerade
    add chain=srcnat out-interface=wlan2 action=masquerade
    add chain=input in-interface=wlan1 action=mark-connection new-connection-mark=wlan1_conn
    add chain=input in-interface=wlan2 action=mark-connection new-connection-mark=wlan2_conn
    add chain=output connection-mark=wlan1_conn action=mark-routing new-routing-mark=to_wla1
    add chain=output connection-mark=wlan1_conn action=mark-routing new-routing-mark=to_wla2
    / ip route
    add dst-address=0.0.0.0/0 gateway=10.111.0.1 routing-mark=to_wla1
    add dst-address=0.0.0.0/0 gateway=10.112.0.1 routing-mark=to_wla2
  2. Thanks rznrz06 thanked for this post
  4. #62
    کاربر عادی alifallah17 آواتار ها
    Apr 2015
    31
    زحمت کشیدی!
  5. #63
    کاربر عادی rznrz06 آواتار ها
    Aug 2012
    4
    درود
    ببخشید که دوباره مزاحم میشم.
    همانطور که قبلاً هم گفتم هدف من اینه که 3 تا Adsl هر کدام 8 مگابیتی هستند رو با هم ترکیب کنم و یک سرعت تک کانکشن حداقل 20 مگابیتی به دست بیارم.
    اول اینکه با این دستگاه هم امکان پذیر هستش؟
    2- با چه دستگاهی بهترین جواب رو میگیرم؟ مدل و قیمت و اگه میشه محل فروش؟
    3-دستورالعملی که فرمودین رو این دستگاه هم پیاده میشه؟
    قابل توجه که من میخوام سرعت وبگردی و آنلاین فیلم نگاه کردن به Netflix 4K بالا بره و بتونم فیلم با کیفیت 4K رو مستقیم ببینم.( احتیاج به سرعت 20 مگابیت دارم)
    در کل میخوام اذیت نکنه.
    خیلی خیلی ممنون.
    XPERIA Z3
  6. #64
    Apr 2014
    Esfahan, kashan
    1,288
    نصب و راه اندازی دستگاه ۵ Metal میکروتیک (امنیت کالا)
    رادیو روتر ارزان قیمت ضد آب متال میکروتیک با پوشش فلزی به منظور خنک کنندگی هر چه بیشتر با قدرت بسیار بالای ۳۱dbm بدون آنتن با قابلیت اتصال به همه نوع آنتن قابل استفاده به عنوان فرستنده در شبکه های نقطه به نقطه در شبکه های بیسیم میباشد
  7. Thanks farzad25 thanked for this post
  8. #65
    Apr 2014
    Esfahan, kashan
    1,288
    راه اندازی سرویس Capsman در میکروتیک
    سرویس CAPS MAN میکروتیک وایرلس Wireless
  9. #66
    Apr 2014
    Esfahan, kashan
    1,288
    آموزش میکروتیک mtcna - قسمت اول
    شروع آموزش های میکروتیک
  10. Thanks r4ptor thanked for this post
  11. #67
    Apr 2014
    Esfahan, kashan
    1,288
    اموزش میکروتیک mtcna - قسمت دوم
  12. Thanks r4ptor thanked for this post
  13. #68
    Apr 2014
    Esfahan, kashan
    1,288
    آموزش میکروتیک mtcna - قسمت سوم
  14. Thanks r4ptor thanked for this post
  15. #69
    Apr 2014
    Esfahan, kashan
    1,288
    آموزش mtcna میکروتیک - قسمت چهارم
  16. Thanks r4ptor thanked for this post
  17. #70
    Apr 2014
    Esfahan, kashan
    1,288
    آموزش mtcna میکروتیک - قسمت پنجم
  18. Thanks r4ptor thanked for this post
