udp://tracker.coppersurfer.tk:6969
udp://tracker.leechers-paradise.org:6969
udp://tracker.opentrackr.org:1337/announce
udp://torrent.gresille.org:80/announce
udp://9.rarbg.me:2710/announce
udp://p4p.arenabg.com:1337
udp://tracker.internetwarriors.net:1337
MMM MMM KKK TTTTTTTTTTT KKK
MMMM MMMM KKK TTTTTTTTTTT KKK
MMM MMMM MMM III KKK KKK RRRRRR OOOOOO TTT III KKK KKK
MMM MM MMM III KKKKK RRR RRR OOO OOO TTT III KKKKK
MMM MMM III KKK KKK RRRRRR OOO OOO TTT III KKK KKK
MMM MMM III KKK KKK RRR RRR OOOOOO TTT III KKK KKK
MikroTik RouterOS 6.35 (c) 1999-2016
[?] Gives the list of available commands
command [?] Gives help on the command and list of arguments
[Tab] Completes the command/word. If the input is ambiguous,
a second [Tab] gives possible options
/ Move up to base level
.. Move up one level
/command Use command at the base level
[email protected]] > export
# apr/12/2016 11:11:13 by RouterOS 6.35
# software id = RFNE-MAXF
/interface ethernet
set [ find default-name=ether3 ] auto-negotiation=no
/interface pppoe-client
add add-default-route=yes default-route-distance=1 disabled=no interface=ether2 \
keepalive-timeout=300 max-mru=1480 max-mtu=1480 mrru=1600 name=pppoe-out1 \
/interface wireless security-profiles
set [ find default=yes ] supplicant-identity=MikroTik
/ip hotspot profile
set [ find default=yes ] http-cookie-lifetime=4d login-by=\
mac,cookie,http-chap,http-pap,mac-cookie
add dns-name=www.kosar--nab.com hotspot-address=172.72.72.5 \
http-cookie-lifetime=5d login-by=cookie,http-chap,https,mac-cookie name=\
hsprof1 use-radius=yes
/ip hotspot user profile
set [ find default=yes ] keepalive-timeout=6d8m mac-cookie-timeout=6d \
shared-users=5 status-autorefresh=8m
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc
/ip pool
add name=hs-pool-3 ranges=192.168.200.2-192.168.200.254
add name=dhcp_pool1 ranges=192.168.200.2-192.168.200.254
add name=hs-pool-5 ranges=192.168.30.2-192.168.30.254
add name=hs-pool-6 ranges=192.168.60.1-192.168.60.4,192.168.60.6-192.168.60.254
add name=dhcp_pool2 ranges=172.18.10.1-172.18.10.4,172.18.10.6-172.18.10.254
add name=dhcp_pool3 ranges=172.18.10.2-172.18.10.254
add name=dhcp_pool4 ranges=172.18.10.2-172.18.10.254
add name=dhcp_pool5 ranges=172.18.10.2-172.18.10.254
add name=dhcp_pool6 ranges=172.18.10.1-172.18.10.4,172.18.10.6-172.18.10.254
add name=dhcp_pool7 ranges=\
192.168.40.1-192.168.40.4,192.168.40.6-192.168.40.254
add name=dhcp_pool8 ranges=\
192.168.90.1-192.168.90.4,192.168.90.6-192.168.90.254
add name=dhcp_pool9 ranges=172.0.0.1-172.72.72.4,172.72.72.6-172.255.255.254
/ip dhcp-server
add address-pool=dhcp_pool1 disabled=no interface=ether3 lease-time=3d name=\
dhcp1
add address-pool=hs-pool-5 interface=ether5 lease-time=1h name=dhcp2
add address-pool=hs-pool-6 interface=ether6 lease-time=1h name=dhcp3
add address-pool=dhcp_pool6 interface=ether8 lease-time=3d name=dhcp4
add address-pool=dhcp_pool7 interface=ether11 lease-time=3d name=dhcp5
add address-pool=dhcp_pool8 interface=ether9 lease-time=3d name=dhcp6
add address-pool=dhcp_pool2 disabled=no interface=ether10 lease-time=1h name=\
dhcp7
/ip hotspot
add address-pool=dhcp_pool2 disabled=no interface=ether10 name=hotspot1 \
profile=hsprof1
/tool user-manager customer
set admin access=\
own-routers,own-users,own-profiles,own-limits,config-payment-gw
/ip firewall connection tracking
set enabled=yes
/ip settings
set rp-filter=strict
/ip address
add address=192.168.88.1/24 comment="default configuration" interface=ether1 \
network=192.168.88.0
add address=192.168.30.5/24 interface=ether5 network=192.168.30.0
add address=192.168.200.5 disabled=yes interface=ether3 network=192.168.200.0
add address=192.168.60.5/24 disabled=yes interface=ether6 network=192.168.60.0
add address=192.168.40.5/24 comment="Connect to Access point" interface=ether11 \
network=192.168.40.0
add address=172.16.20.1/24 interface=ether13 network=172.16.20.0
add address=192.168.90.5/24 disabled=yes interface=ether9 network=192.168.90.0
add address=172.72.72.5/8 interface=ether10 network=172.0.0.0
add address=94.183.240.225/29 comment="test connection netroniks" interface=\
ether4 network=94.183.240.224
add address=192.168.20.5/24 interface=ether12 network=192.168.20.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-relay
add dhcp-server=192.168.200.1 disabled=no interface=ether5 name=relay1
/ip dhcp-server network
add address=172.0.0.0/8 gateway=172.72.72.5
add address=172.18.10.0/24 dns-server=85.15.1.14,172.18.10.125,8.8.8.8 gateway=\
172.18.10.5
add address=192.168.30.0/24 comment="hotspot network" dns-server=85.15.1.14 \
gateway=192.168.30.5
add address=192.168.40.0/24 dns-server=85.15.1.14,8.8.8.8 gateway=192.168.40.5
/ip dns
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=172.16.20.2 name=kosar--user.com
/ip firewall address-list
add address=192.168.40.0/24 list=User
add address=192.168.60.0/24 list=User
add address=192.168.30.0/24 disabled=yes list=User
add address=172.16.20.2 list=bypass
add address=192.168.20.250 list=bypass
/ip firewall filter
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" \
disabled=yes
add action=drop chain=forward disabled=yes dst-address-list=User \
src-address-list=User
add action=jump chain=forward comment=DDOS connection-state=new disabled=yes \
jump-target=detect-ddos
add action=return chain=detect-ddos disabled=yes dst-limit=\
32,32,src-and-dst-addresses/10s
add action=add-dst-to-address-list address-list=ddosed address-list-timeout=10m \
add action=add-src-to-address-list address-list=ddoser address-list-timeout=10m \
add action=drop chain=input comment="DROP DNS REQUST" disabled=yes dst-port=53 \
in-interface=pppoe-out1 protocol=udp
add action=drop chain=input disabled=yes dst-port=53 in-interface=pppoe-out1 \
protocol=tcp
add action=jump chain=forward comment="SYN Flood protect" connection-state=new \
disabled=yes jump-target=SYN-Protect protocol=tcp tcp-flags=syn
add action=tarpit chain=input connection-limit=3,32 disabled=yes protocol=tcp \
src-address-list=blocked-addr
add action=drop chain=SYN-Protect connection-state=new disabled=yes protocol=\
tcp tcp-flags=syn
add chain=forward comment=Torrent disabled=yes p2p=all-p2p protocol=udp
add action=drop chain=forward connection-state=new disabled=yes \
dst-address-list=ddosed src-address-list=ddoser
/ip firewall mangle
add action=log chain=postrouting disabled=yes dst-port=8009 log=yes protocol=\
tcp
add action=log chain=prerouting disabled=yes dst-port=8009 log=yes protocol=tcp
/ip firewall nat
disabled=yes
add action=dst-nat chain=dstnat comment="remote to sib" dst-address=\
94.183.240.146 dst-port=2222 log=yes protocol=tcp to-addresses=172.16.20.2 \
to-ports=22
add action=dst-nat chain=dstnat comment="Remot Desktop Server Haris" \
dst-address=94.183.240.146 dst-port=3389 log=yes protocol=tcp to-addresses=\
192.168.20.253 to-ports=3389
add action=dst-nat chain=dstnat comment="Connect To CCTV Server" dst-address=\
94.183.240.146 dst-port=8080 log=yes protocol=tcp to-addresses=\
192.168.20.227 to-ports=8080
add action=dst-nat chain=dstnat comment="Reservation Online Nat" dst-address=\
94.183.240.146 dst-port=8085 log=yes protocol=tcp to-addresses=\
192.168.20.253 to-ports=80
add action=dst-nat chain=dstnat comment="Freenas Kosar Connection" dst-address=\
94.183.240.146 dst-port=8088 log=yes protocol=tcp to-addresses=\
192.168.30.235 to-ports=80
add action=masquerade chain=srcnat out-interface=ether2
add action=masquerade chain=srcnat comment="masquerade hotspot network" \
dst-address=!172.16.20.2 src-address=192.168.30.0/24
dst-address=!172.16.20.2 src-address=192.168.60.0/24
add action=dst-nat chain=dstnat comment="URL reportin" dst-address-list=!bypass \
dst-port=80 protocol=tcp src-address-list=User to-addresses=172.16.20.2 \
to-ports=3128
dst-address=!172.16.20.2 src-address=192.168.40.0/24
add action=masquerade chain=srcnat src-address=172.16.20.10
add action=masquerade chain=srcnat src-address=172.16.20.2
add action=masquerade chain=srcnat comment="CONNECT TO RESERVATION SRCNAT" \
src-address=192.168.20.253
add action=masquerade chain=srcnat comment="CONNECT TO FREENAS SRCNAT" \
src-address=192.168.30.235
add action=masquerade chain=srcnat comment="CONNECT TO CCTV SRCNAT" \
src-address=192.168.20.227
add chain=hs-unauth dst-address=172.16.20.2 src-address=192.168.40.0/24
add chain=hs-unauth dst-address=172.16.20.2 src-address=192.168.60.0/24
add action=masquerade chain=srcnat comment="masquerade hotspot network" log=yes \
src-address=172.0.0.0/8
/ip firewall service-port
set ftp disabled=yes
/ip hotspot ip-binding
add address=94.183.240.146 disabled=yes to-address=192.168.20.250
/ip hotspot user
/ip hotspot walled-garden
add comment="place hotspot rules here" disabled=yes
add dst-host=www.apple.com path=/library/test/success.html
add dst-host=*.apple.com
add dst-host=airport.us
add dst-host=itools.info
add dst-host=appleiphonecell.com
add dst-host=thinkdifferent.us
add dst-host=ibook.info
add dst-host=kosar--nab.com
add dst-host=http://www.apple.com/library/test/success.html
add dst-host=*.apple.com.edgekey.net
add dst-host=*.akamaiedge.net
add dst-host=*.akamaitechnologies.com
add dst-host=192.168.20.250/webrest
/ip hotspot walled-garden ip
add action=accept disabled=no dst-address=172.16.20.2 src-address=\
192.168.40.0/24
192.168.60.0/24
add action=accept disabled=no dst-address=172.16.20.2 src-address=172.0.0.0/8
add action=accept disabled=no src-address=192.168.20.202
add action=accept disabled=no src-address=172.72.72.5
/ip ipsec policy
set 0 dst-address=0.0.0.0/0 src-address=0.0.0.0/0
/ip *****
set cache-path=web-proxy1
/ip route
add comment="ertebat ba server haris" disabled=yes distance=1 dst-address=\
192.168.20.0/24 gateway=ether4
add comment="rout for 450 test" distance=1 dst-address=192.168.200.0/24 \
gateway=ether3
/ip service
set telnet disabled=yes
set www disabled=yes port=8008
set www-ssl disabled=no
set winbox port=8008
/radius
add address=172.16.20.2 secret=09123898150 service=hotspot src-address=\
172.16.20.1 timeout=3s
/radius incoming
set accept=yes port=1700
/system clock
set time-zone-name=Asia/Tehran
/system identity
set name=KosaRouter
/system ntp client
set enabled=yes primary-ntp=4.2.2.4
/system script
add comment="special for iphone for hot spot problem" name=script1 owner=admin \
policy=ftp,reboot,read,write,policy,test,password, sniff,sensitive source="/i\
p hotspot walled-garden\r\
\nadd dst-host=www.apple.com path=/library/test/success.html\r\
\nadd dst-host=*.apple.com\r\
\nadd dst-host=airport.us\r\
\nadd dst-host=itools.info\r\
\nadd dst-host=appleiphonecell.com\r\
\nadd dst-host=thinkdifferent.us\r\
\nadd dst-host=ibook.info"
add comment="ios script for hotspot " name=script2 owner=admin policy=\
ftp,reboot,read,write,policy,test,password,sniff,s ensitive source="/ip hotsp\
ot walled-garden\r\
\nadd dst-host=ibook.info\r\
\nadd action=allow disabled=no dst-host=*.apple.com dst-port=""\r\
\nadd action=allow disabled=no dst-host=*.apple.com.edgekey.net dst-port="\
"\r\
\nadd action=allow disabled=no dst-host=*.akamaiedge.net dst-port=""\r\
\nadd action=allow disabled=no dst-host=*.akamaitechnologies.com dst-port="\
"\r\
\n/ip hotspot walled-garden ip\r\
\nadd action=accept disabled=no dst-host=captive.apple.com\r\
\nadd action=accept disabled=no dst-host=www.appleiphonecell.com\r\
\nadd action=accept disabled=no dst-host=www.itools.info\r\
\nadd action=accept disabled=no dst-host=www.ibook.info\r\
\nadd action=accept disabled=no dst-host=www.airport.us\r\
\nadd action=accept disabled=no dst-host=www.thinkdifferent.us\r\
\nadd action=accept disabled=no dst-host=static.ess.apple.com\r\
\nadd action=accept disabled=no dst-host=init-p01md.apple.com\r\
\nadd action=accept disabled=no dst-host=ess.apple.com\r\
\nadd action=accept disabled=no dst-host=apple.com\r\
\nadd action=accept disabled=no dst-host=gps.apple.com\r\
\n"
/tool traffic-monitor
[admin
@KosaR
outer]
[email protected]] > cls
bad command name cls (line 1 column 1)
[email protected]] > clear
bad command name clear (line 1 column 1)
[email protected]] > exit
bad command name exit (line 1 column 1)
[email protected]] > console
.. -- go up to root
clear-history -- clear command history for all users
[email protected]] > console clear-history
[email protected]] > clear-history
bad command name clear-history (line 1 column 1)
! whitespace
; end of command
[admin
@KosaR
outer]
echo:
system
,error
,criti
cal lo
gin fa
ilure
for us
er Ale
x from
95.37
.89.13
2 via
ftp
[admin
@KosaR
outer]
