موضوع: EnableDeadGWDetect Help
    کاربر عادی farhadtm7 آواتار ها
    Aug 2007
    58
    پیش فرض EnableDeadGWDetect Help
    در مورد مطلب زیر کسی می تونه راهنمایی کنه؟ من نتونستم ازش استفاده کنم.
    EnableDeadGWDetect
    HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Param eters
    Data type Range Default value
    REG_DWORD
    0 | 1
    Description
    Determines whether TCP performs dead gateway detection. Dead gateway detection is a TCP feature that identifies gateways that are not operating properly and that switches the computer to a new default gateway.
    When enabled, any given connection defines a gateway as non-operational ( dead ) when a packet sent to the gateway must be retransmitted more than half of the number of times specified in the value of the TcpMaxDataRetransmissions entry. The connection switches to the next gateway in the list in the DefaultGateway or DhcpDefaultGateway entries. The system defines a gateway as dead when more than 25 percent of its connections have switched to the next default gateway in the list.
    Value Meaning
    0
    Disables dead gateway detection
    Enables dead gateway detection
    Change method
    To define backup gateways, use Network and Dial-up Connections. Right-click Local Area Connection, click Properties, click Internet Protocol (TCP/IP), and then click the Properties button. On the General tab, click the Advanced button, click the IP Settings tab, and then, in the Default gateways, in order of use section, click Add.
    Note
    Windows 2000 does not add this entry to the registry. You can add it by editing the registry or by using a program that edits the registry.
    Refrence
    Aug 2007
    58
    کسی نیست جوابی بده؟
    می گه که اگر این و فعال کنید میاد gateway رو چک می کنه که سالم هست یا نه..بر اساس TcpMaxDataRetransmissions
    اگر تشخیص بر از بین رفتن gateway بده , اونوقت از gateway های پشتیبان که بوسیله dhcp یا خودتون دستی اضافه کردید استفاده می کنه
    برای دستی اضافه کردن این مسیر هست
