موضوع: Help,,,trunking Problem In 2924 Switch(any Trunking Expert)
    کاربر عادی dileswar آواتار ها
    Nov 2007
    Question Help,,,trunking Problem In 2924 Switch(any Trunking Expert)
    Dear frnds..........
    i want to configure trunk between two 2924 cisco switches but it is not showing the option for trunk.i am giving the details of the switch below.so plz help me to short it out soon................
    below is the out put of sh version command
    SW1#sh version
    Cisco Internetwork Operating System Software
    IOS C2900XL Software (C2900XL-H-M), Version 11.2(8)SA3, RELEASE SOFTWARE (fc1)
    Copyright 1986-1998 by cisco Systems, Inc.
    Compiled Fri 11-Sep-98 17:00 by rheaton
    Image text-base: 0x00003000, data-base: 0x001C4910
    ROM: Bootstrap program is C2900XL boot loader
    SW1 uptime is 2 hours, 17 minutes
    System restarted by reload
    Running default software
    cisco WS-C2924C-XL (PowerPC403GA) processor (revision 0x11) with 4096K/1024K bytes o
    f memory.
    Board ID 0x09
    Last reset from warm-reset
    24 Ethernet/IEEE 802.3 interface(s)
    32K bytes of flash-simulated non-volatile configuration memory.
    Base ethernet MAC Address: 00:50:E2:C6:B0:40
    Configuration register is 0xF
    when i am giving the switchport mode command the out put is the below and some more commands are showing below...
    SW1#conf t
    Enter configuration commands, one per line. End with CNTL/Z.
    SW1(config)#int fa0/24
    SW1(config-if)#switchport mode ?
    access Non-trunking, non-tagged single VLAN L2 interface desired
    multi Non-tagged, multi-protocol trunk desired
    SW1(config-if)#sw
    SW1(config-if)#switchport ?
    access Set the VLAN when the port is access mode
    mode Select the type of L2 interface desired
    multi Set the VLANs when the port is in multi mode
    SW1(config-if)#switchport multi
    % Incomplete command.
    SW1(config-if)#switchport multi ?
    vlan A list of VLANs
    SW1(config-if)#switchport multi vlan ?
    <1-1001> VLAN index
    SW1(config-if)#switchport multi vlan 1 1001
    SW1#sh int f0/24 switchport
    % Invalid input detected at '^' marker.
    SW1#sh int f0/24 ?
    accounting Show interface accounting
    crb Show interface routing/bridging info
    irb Show interface routing/bridging info
    link-trap Show interface traps on no link
    <cr>
    so plz give the solution how to configure trunk on this switch ....................................help
    plz write your in english...
